Author Topic: how to get the element connected to a UseCase in a Diagram  (Read 9706 times)
andrev
« on: June 30, 2017, 09:50:32 pm »
Started to build a Script in Jscript to get all objects from a diagram, but i have no guarantee that the object is connected to the useCase.
How to get all objects connected to a usecase?
Re: how to get the element connected to a UseCase in a Diagram
« Reply #1 on: June 30, 2017, 09:56:44 pm »
Retrieve the element from the ElementID (using Repository.GetElementByID) and look up the element's Connectors collection.
andrev
« Reply #2 on: June 30, 2017, 10:00:38 pm »
u can show a simple code, to undertand this
« Reply #3 on: June 30, 2017, 10:03:43 pm »
I don't speak JScript. Look into the example scripts provided by Sparx to get an idea how to achieve that.
andrev
« Reply #4 on: June 30, 2017, 10:22:42 pm »
in javascript?
« Reply #5 on: June 30, 2017, 11:32:37 pm »
i no js no java no eql
stand
u
« Reply #6 on: July 01, 2017, 05:01:58 pm »
Andrev,
You will have to show some more effort from your side then only send me teh codez
For your information I have a open source library with hundreds of VBScripts on github: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library
and an even bigger library of C# code dealing with EA
- https://github.com/GeertBellekens/Enterprise-Architect-Toolpack
- https://github.com/GeertBellekens/Enterprise-Architect-Add-in-Framework
- https://github.com/GeertBellekens/UML-Tooling-Framework
This is full with examples on how to use the EA API, but you will have to do the search and translate work yourself.
andrev
« Reply #7 on: July 04, 2017, 09:20:19 pm »
Sorry geert, idk how to get the connector informations, i just wat a example, note the whole code... I'm sorry if it just seemed like I just wanted you to do my job.
« Reply #8 on: July 04, 2017, 09:24:59 pm »
As I told you on StackOverflow: RTFM. This is not a tutorial place. Put in some effort to solve that yourself. If you then get stuck: ask.
andrev
« Reply #9 on: July 04, 2017, 09:36:14 pm »
my effort is this script tha gets all usecases and requeriments from a useCase Diagram http://imgur.com/a/QPbXN
But the order it gets is wrong,im my script, the order is:
requeriment: DOTZ
UseCase: uc7210
UseCase: uc 7172
Requeriment: crediário
Requeriment: débito
the second use case returns correct, but not the first..
this is my code:
function main()
var CSV_DELIMITER = ";";
var filePath = OpenCSVFileDialog();
//abort if no file was specified
if ( filePath == null || filePath == "" )
return;
Repository.EnsureOutputVisible("Script");
Repository.ClearOutput("Script");
Session.Output("Exportando diagrama para: " + filePath);
var exportFile; // : FileSystemObject
var exportColumns;
var exportIsExporting = false;
var currentDiagram as EA.Diagram;
currentDiagram = Repository.GetCurrentDiagram();// collect the actual diagram
var dObjs = currentDiagram.DiagramObjects; // collection of diagram objects
var columns = new Array("Caso de Uso","Descrição","Produtos"); // array with columns names
var fsObject = new ActiveXObject( "Scripting.FileSystemObject" );
var exportFile = fsObject.CreateTextFile( filePath, true );
exportColumns = columns;
// Export column headings if the option was enabled
var headingString = "";    // column Title
for ( var i = 0 ; i < columns.length ; i++ )
if ( i == 0 )
headingString += exportColumns[i];
else
headingString += CSV_DELIMITER + exportColumns[i];
exportFile.WriteLine( headingString );
var rowString = "";
for (var i = 0 ; i < dObjs.Count ; i++)
  // current diagram object
var dObj = dObjs.GetAt(i);
  var obj = Repository.GetElementByID  (dObj.ElementID); // related element
  rowString = "";
Session.Output("tipo" + obj.Type );
if (obj.Type == "UseCase" || obj.Type == "Requirement"){ //only want UCs
if(obj.Type == "Requirement")
rowString += CSV_DELIMITER + CSV_DELIMITER +obj.name;
else
rowString += obj.Name + CSV_DELIMITER + obj.Notes ;
var linha  = rowString.trim();
Session.Output(linha);
        exportFile.WriteLine( linha );
// Clean up file object and column array
exportFile.Close();
exportFile = null;
exportColumns = null;
Session.Output("Diagrama exportado para: " + filePath);
// remove spaces like function TRIM in Javascript
String.prototype.trim = function () {
    return this.rTrim().lTrim();
String.prototype.lTrim = function () {
    var whitespace = new RegExp("^\\s+","gm");
    return this.replace(whitespace, "");
String.prototype.rTrim = function () {
    var whitespace = new RegExp("\\s+$","gm");
// open the dialog window to choose the save path
function OpenCSVFileDialog()
var Project;
var Filename, FilterString, Filterindex, Flags, InitialDirectory, OpenorSave, filepath;
Filename = "";
FilterString = "CSV Files (*.csv)|*.csv|All Files (*.*)|*.*||";
Filterindex = 1;
Flags = 0;
InitialDirectory = "";
OpenorSave = 1;
Project = Repository.GetProjectInterface();
filepath = Project.GetFileNameDialog(Filename, FilterString, Filterindex, Flags, InitialDirectory, OpenorSave);
return filepath;
main();
Because of that I was thinking of looking for the connectors, but i idk how to use get the connectors...
« Reply #10 on: July 04, 2017, 09:50:13 pm »
Well, that's "some code" but none related to your original question.
Aaron B
« Reply #11 on: July 05, 2017, 12:21:49 pm »
What order were you expecting? Looping the DiagramObjects collection will give you a collection of all objects on the diagram, but not in any particular order. If you need them in a specific order you may need to do some further processing.
