Author Topic: Defining RefGUIDs via UML profile limits to 1 tagggedValue-Connector, cause: XML  (Read 7406 times)
Shegit Brahm
Base eap to define a UML profile with
- stereotype "myStereo" extending metaclass Action (myStereo1 for only one per attribute, myStereo2 for more than one)
- several attributes for this stereotype
- connector "taggedValue" between metaclass Action, ActivityInitial and Decision
- connector role specified as attributes names intend
exporting as MDG Technology or UML profile
Use eap to have tagged values depending on stereotype
- creating activity diagram with at least one element for each type of metaclass in base eap
- importing MDG Technology/ UML profile
- creating Action "useStereo1" and Action "useStereo2" in Activity diagram
- setting "myStereo1" and "myStereo2" as stereotype for this action.
- defining entries for each tagged value of both actions
what is:
- every tv is limited to only one metaclass
what should:
- every tv is limited to each metaclass as defined in base eap
source of problem:
- generated xml selected one metaclass by random
"workaround":
- editing xml so that 'notes="Type=RefGUID;Metatype=Action,Decision,...;"
With the XML I can achieve almost any limitation.
But that's what the generated xml should do as well.
example files:
https://www.dropbox.com/s/500b4as78dw3vfy/RefGUID_difference_GUI_XML_Base.eap?dl=1 eap used to define stereotypes with tagged values
https://www.dropbox.com/s/a7rhs8o0hhpnjmo/RefGUIDandRefGUIDs.xml?dl=1 MDG generated by EA
https://www.dropbox.com/s/0pr3ve1e7vauwj8/RefGUIDandRefGUIDs_Edited.xml?dl=1 MDG edited to achieve aimed behavior
https://www.dropbox.com/s/1zknc7cyi9ypmtz/RefGUID.xml?dl=1 UML profile for single tagged value connectors
https://www.dropbox.com/s/d9s2hzeivtwooh0/RefGUIDs.xml?dl=1  UML profile for multiple tagged value connectors
https://www.dropbox.com/s/tnzom6j02zh20vt/RefGUIDs_AllTargetSet.png?dl=1 diagram RefGUIDs with multiple connectors
(edit: changed dropbox links to start download directly (dl=1) instead opening dropbox page (dl=0))
general discussion took place here:
http://sparxsystems.com/forums/smf/index.php/topic,38459.0.html
« Last Edit: July 14, 2017, 12:15:27 am by Shegit Brahm »
The links do not work for me.
Shegit Brahm
tested links in different browser with being logged out in dropbox. works.
changed to offer files directly instead opening download page.
Now it worked. Will have a look.
Just at a quick look: the <<taggedValue>> needs a role name which you have not assigned. You should see a warning in EA's System Console
UML Export: Association relationship [ActionTV]---[Class] ignored as no valid identifier exists (link name or destination role)
Open the connector properties and assign a role name to TARGET.
Shegit Brahm
I moved extend connector around to clarify: all TARGET are set:
this "candidate as bug" came from your help in topic http://sparxsystems.com/forums/smf/index.php/topic,38459.0.html
thanks, Shegit
« Last Edit: July 14, 2017, 12:15:55 am by Shegit Brahm »
Getting MDG to work is not a piece of cake. You have to swallow some not so tasty pieces too. And coffee isn't served as well. You have to make your own.
