Author Topic: Generate documentation: Tables and shapescripts  (Read 3976 times)
Hurra
    • Find me at LinkedIn!
« on: July 17, 2017, 06:18:44 pm »
Hello!
I have an output to show connections to/from the current selected element as follows:
package >
HEADING 1 {Pkg.Name}
element >
HEADING 2 {Element.Name}
{Element.Notes}
connector >
source >
element >
{Element.Name}
< element
< source
{Connector.Name}
target >
element >
{Element.Name}
< element
< target
< connector
< element
< package
However, I would like to show it in a table:
SourceConnectionTarget
Source #1Connection #1Target #1
The problem is though that the information is in different section-contents (or whatever it is called, i.e. connector >, source >). I can't get all the information in the table. Is there a way around this?
Second question:
Is there a way to include the shapescript of elements/stereotypes? I found insert image and similar, but since the shapescript is embedded with the element/stereotype I thought it would be easy to show the image/shapescript. I do not find anything. Someone knows something about this?
Cheers!
« Last Edit: July 17, 2017, 06:21:18 pm by RWHurra »
always learning!
Hurra
Re: Generate documentation: Tables and shapescripts
« Reply #1 on: August 07, 2017, 11:18:22 pm »
I solved the element image with pasting the image in a linked document. I did not manage to solve the table issue.
always learning!
