Author Topic: Script diagram "collapse embedded elements"?  (Read 8013 times)
Mr Stuff
« on: July 19, 2017, 07:06:13 pm »
Can anyone tell me what/how to set/clear?
A quick check of the diagram's extended style shows the parameter isn't in there... nor do I see any other obvious location for it.
Thanks - Julian
Re: Script diagram "collapse embedded elements"?
« Reply #1 on: July 19, 2017, 10:17:12 pm »
It's simply done by removing/adding the according diagramObject.
Mr Stuff
« Reply #2 on: July 20, 2017, 03:41:23 pm »
Thanks, but that's not really the issue The diagram properties dialog* has a check box to "collapse embedded objects", which reduces their appearance to black dots on the element edge.
I don't want to remove the diagram objects merely enable/disable this display option.
*right-click on diagram background... Properties... Elements... "collapse embedded objects" check box.
Helmut Ortmann
« Reply #3 on: July 20, 2017, 03:50:59 pm »
Hi Mr Stuff,
I don't catch your issue. Think about making a little concrete example. What embedded objects do you have in mind? A little picture would make it clear.
In EA you can control the appearance of:
- Diagram
- Diagram nodes
- Diagram links
If you want e.g. not show Ports on a Diagram, there is at least one Addin that solves the issue.
Kind regards,
Helmut
« Reply #4 on: July 20, 2017, 04:13:29 pm »
Thanks - Julian
t_diagram.StyleEx includes "CEE=1;"
Mr Stuff
« Reply #5 on: July 20, 2017, 04:29:53 pm »
@KP  :) I just found that while waiting for further answers...
following fragment toggles Collapse Embedded Elements
newStyleEx = curDiag.StyleEx
if instr(newStyleEx, "CEE=1;") > 0 then
newStyleEx = Replace (newStyleEx, "CEE=1;", "")
else
' just to be safe, follow the Sparx pattern of putting the CEE=1 value just before the Theme
newStyleEx = Replace (newStyleEx, "Theme=", "CEE=1;Theme=")
end if
curDiag.StyleEx = newStyleEx
curDiag.Update
Repository.ReloadDiagram(curDiag.DiagramID)
Thanks, Julian
