Author Topic: Document Generation - include package at different levels  (Read 4567 times)
michielper
« on: August 07, 2017, 06:59:54 pm »
I am using the EA Document generator to generate reasonably large documents (50-150 pages).
From one model, I generate two different documents by using two different Model Documents.
The two documents share a number of packages from the model but.... I want those packages placed at different paragraph-levels. This seems not to be possible in a Model Document: all included packages are placed at the top level.
Is there a trick to accomplish what I want? One might think of creating a "package link" that points to the actual package and can itself be included at a different loction in the project browser tree. But I dont think that exists :-(.
Thanks for any suggestions!
« Last Edit: August 07, 2017, 07:01:30 pm by michielper »
peterc
Re: Document Generation - include package at different levels
« Reply #1 on: August 18, 2017, 12:50:22 am »
I may have got the wrong end of the stick...
I presume that you have some parameter (e.g. Element Name) with a Paragraph Style of Heading 1 or Heading 2 etc.
If you have two templates then you can start from a different Paragraph Style in each.
For example, if you have a package called Requirements and in one template set the Paragraph Style to be Heading 2 and include Element Name in the heading then (assuming you use numbered headings) you will have something like "1.1 Requirements".
If you then choose in your other template Heading 3 as the Paragraph Style then the package name would be "1.1.1 Requirements".
As I said, I may have misunderstood your need.
michielper
« Reply #2 on: March 21, 2018, 11:58:12 pm »
This might be a solution indeed, together with combining documents in a Master Document.
