Author Topic: Support for Mercurial (version control tool)  (Read 8480 times)
Viking
« on: August 09, 2017, 03:02:26 am »
Hi, is there Mercurial support in the meantime? The only article I fould for this topic is from 2010 (http://sparxsystems.com/forums/smf/index.php?topic=29252.0). Many thanks in advance, V.
Re: Support for Mercurial (version control tool)
« Reply #1 on: August 09, 2017, 09:09:51 am »
You would still need an SCC interface.
Incidentally, SCC is a generic "Generic VCS interface" as requested by the last post in that thread. It's a common API that developers can write to wrap their VCS.
Viking
« Reply #2 on: August 10, 2017, 02:23:48 am »
Many thanks. Do I undestand you correctly that there is no SSC-compliant Mercurial-library coming with EA? So I need to get it from somewhere? Are there any addresses in the internet? I can only find the library linked in the thread mentioned above. V.
« Reply #3 on: August 10, 2017, 08:26:47 am »
EA doesn't include any SCC providers. I don't know anything about Mercurial other than these two threads, so I can't help you with SCC support for it.
Uffe
« Reply #4 on: August 14, 2017, 08:48:15 pm »
Yes.
Yes. Or roll your own.
Many.
/Uffe
Viking
« Reply #5 on: August 15, 2017, 03:19:05 am »
Could you tell me a good address resp. a reliable supplier, please? I found only hgscc.
« Last Edit: August 15, 2017, 04:58:12 pm by Viking »
Uffe
« Reply #6 on: August 15, 2017, 07:16:33 pm »
Sorry, no. You're looking at a couple weeks work there at least. I could do it but I'd have to charge. 8)
I'm not even sure it's possible. There's a reason Mercurial dropped it in the first place.
/U
Viking
« Reply #7 on: August 15, 2017, 07:34:00 pm »
/U
I am sorry. I do not understand. I asked if there are "suppliers for SSC for Mercurial" and you answered "many". Then I asked if you could tell me a reliable supplier and you answer that there would be a lot of work to do. I am just looking for a SSC interface which can be used for Mercurial.
Uffe
« Reply #8 on: August 15, 2017, 08:34:55 pm »
No, you asked if there are any addresses in the Internet. There are many. In fact, some four billion in the IPv4 address space alone.
Evaluating suppliers is a lot of work.
As I said, I'm not sure if it's possible to do since Mercurial had SCC support once, and dropped it. Either way, it's nothing to do with EA. You'll likely get better answers from the Mercurial people.
/U
