Author Topic: Diagram swimlane orientation  (Read 7564 times)
rupertkiwi
« on: August 10, 2017, 12:04:45 pm »
Hi there,
How can I add both horizontal and vertical swimlanes to a diagram?
Here is what I have so far:
    Dim heading As EA.Swimlane
    Set heading = testDiagram.SwimlaneDef.Swimlanes.Add("", 50)
    testDiagram.SwimlaneDef.Orientation = soHorizontal
But this will make all swimlanes in the diagram horizontal.
I want some to be vertical and some to be horizontal.
Rupert
Re: Diagram swimlane orientation
« Reply #1 on: August 10, 2017, 02:53:02 pm »
Rupert,
You are changing it on diagram level, but you can also change it at diagramObject level.
Here's the code I use to change the Activitypartitions from Horizontal to vertical (or vice versa)
public void setOrientation(bool vertical)
string currentStyle = this.wrappedDiagramObject.Style.ToString();
string vPartitionValue;
vPartitionValue = vertical ? "1":"0";
this.wrappedDiagramObject.SetStyleEx("VPartition",vPartitionValue);
string styleAfter = this.wrappedDiagramObject.Style.ToString();
rupertkiwi
« Reply #2 on: August 10, 2017, 03:51:06 pm »
Hi Geert,
Thanks for your replay.
I seem to be having a bot of trouble wih it:
Function setOrientation(d As EA.diagram, vertical As Boolean)
Dim diagramObjects As EA.Collection
Set diagramObjects = d.diagramObjects
Dim testDiagramObject As EA.diagramObject
Set testDiagramObject = diagramObjects.AddNew("Test", Swimlane)
testDiagramObject.Style = testDiagramObject.SetStyleEx("VPartition", vertical)
End Function
Can you see what I'm doing wrong?
Many thanks,
Rupert
« Reply #3 on: August 10, 2017, 04:04:58 pm »
You don't call the final Update.
SetStyleEx does not return anything.
« Last Edit: August 10, 2017, 04:07:21 pm by qwerty »
rupertkiwi
« Reply #4 on: August 11, 2017, 12:15:46 pm »
I changed it to match Geert's code more closely but I'm still not having any joy:
    Sub setOrientation(vertical As Boolean, tdo As EA.diagramObject)
    Dim currentStyle As String
    currentStyle = tdo.Style
    Dim vPartitionValue As String
    tdo.SetStyleEx("VPartition",vPartitionValue)
    Dim styleafter As String
    styleafter = this.wrappedDiagramObject.Style
    End Sub
« Reply #5 on: August 11, 2017, 05:50:22 pm »
You still dont call Update.
Aaron B
« Reply #6 on: August 14, 2017, 10:26:04 am »
What qwerty means is that you need to call tdo.Update() in your code to commit your changes.
