Author Topic: SysML prevents using UML use cases  (Read 4043 times)
Guillaume
    • www.umlchannel.com
« on: August 10, 2017, 09:08:59 pm »
I use both SysML and UML on various EA projects.
Somehow I must have enabled an option in EA that I need to get rid of:
- in the toolbox view, the SysML Common is always visible (the common is collapsed)
- in a UML use case diagram, I always get the SysML Use Case toolbox!
Guillaume
Guillaume
Re: SysML prevents using UML use cases
« Reply #1 on: August 10, 2017, 10:28:15 pm »
You can pin toolboxes to be always visible.
Right click on an empty space on your toolbox to see the option.
Guillaume
« Reply #2 on: August 10, 2017, 11:15:58 pm »
Thanks for your reply Geert
However it was a different issue which I since managed to sort out: the SysML 1.3 MDG was set as active. This led to replace my UML statechart toolbox for instance with the SysML toolbox.
It can be changed via Extensions > MDG Technologies > select Basic UML and set as active.
Guillaume
