Author Topic: Dragging orthogonal line styles past ends of aligned objects should create two w  (Read 4421 times)
If you have aligned vertices (of the same size) and you connect them via an orthogonal (square or rounded) arc, you can only drag it to the edge of the vertex.  You can't drag it past.  If the vertices, are of different sizes or are not aligned, then you can get the additional waypoints to bend the arc as required.  It would be good to be able to do this also when the vertices are the same size and aligned.
I decided it was a feature request, but it could be considered a bug.
Reported,
