Author Topic: Can’t display hidden label for Constraint  (Read 5998 times)
« on: August 23, 2017, 10:03:31 am »
We're naming our UML Constraints - so we can tell one from the other.  This will produce a Label.  However, once the label is suppressed (either intentionally or otherwise) there is no mechanism to recover it and make it visible again.
Please Rectify!
Report,
Re: Can’t display hidden label for Constraint
« Reply #1 on: August 23, 2017, 12:10:52 pm »
Constraints don't display a name (in a separate label or otherwise)
« Reply #2 on: August 23, 2017, 04:56:49 pm »
Tell that to my repository.  I can even (and have) coloured them up.
I haven't figured out how to get it to show, but it does (under, as yet, undetermined circumstances)  ...
Even if constraints notionally don't (currently) display their name if assigned, they should!
« Reply #3 on: August 23, 2017, 05:55:31 pm »
In OCL (AFAIK) constraints do have a name. More and more people seem to use OCL. So it would be a good way to add OCL constraints using the name attribute. Just a thought.
« Reply #4 on: August 24, 2017, 09:36:56 am »
Thanks, qwerty,
I thought of that but two reasons why not.
  • Narrative Constraints are, typically, MUCH longer than names.  Anyway, names are identifiers, constraints are descriptive.  There's a semantic mismatch.
  • This bug means I can't display it when I need to and not when I don't.
BTW: I've had a think about why the (name) label is sometimes visible, but I don't have time to follow it up at present.
« Reply #5 on: August 24, 2017, 04:58:52 pm »
You could stereotype your notes and apply a shape script.
shape main {
DrawNativeShape();
print("#name#");
« Last Edit: August 24, 2017, 05:03:29 pm by qwerty »
« Reply #6 on: August 25, 2017, 03:13:04 pm »
If you set Rectangular Notation (in this case via script) the note displays, if not in Rectangular, it doesn't.  So now I can show/hide it at will, so to speak (since my shapescript - and it is a stereotyped Constraint - makes no distinction between Rectangular and Non-Rectangular).
