Author Topic: Use Case x Test Case  (Read 6115 times)
andrev
« on: August 25, 2017, 02:42:53 am »
Tenho uma matriz de caso de uso x casos de test em excell, teria um jeito de importar isso pro EA, sendo assim podendo rastrear os casos de teste para poder sugerir esse fluxo de testes para a equipe de testes?
Re: Use Case x Test Case
« Reply #1 on: August 25, 2017, 04:53:08 am »
Google translate spits out this
I have an array of use cases x test cases in excell, would you have a way to import this to EA, so I can track the test cases to be able to suggest this flow of tests to the test team?
« Reply #2 on: August 25, 2017, 05:55:28 am »
I'm not using the csv importer since I script such tasks usually faster than parametrizing some tool. Anyhow, AFAIK the csv import can only import one dimension. The relation between elements needs to be added manually or with another script. You might look into the csv importer that is provided in EASrciptingLib and modify that to your needs.
andrev
« Reply #3 on: August 25, 2017, 09:16:44 pm »
Thanks, i will try
Graham_Moir
« Reply #4 on: September 04, 2017, 07:10:44 pm »
That's not completely true, a simple hierarchy is supported in the csv importer.  See
http://sparxsystems.com/enterprise_architect_user_guide/13.5/model_publishing/using_preserve_hierarchy.html
« Reply #5 on: September 04, 2017, 08:00:56 pm »
I see. That seems to be a new feature in V13.5
Uffe
« Reply #6 on: September 04, 2017, 09:13:54 pm »
It's been around since version 9 at least.
But the hierarchy it refers to is the project browser, or containment, hierarchy. That is indeed a type of relationship between entities, but it's not a connector. Connectors cannot be imported/exported using EA's built-in CSV functions.
/Uffe
« Reply #7 on: September 04, 2017, 09:55:20 pm »
Ah, thanks. I totally missed that feature.
