Author Topic: Set user password?  (Read 6798 times)
Uffe
Set user password?
« on: October 17, 2011, 11:05:13 pm »
Hi all,
I'm wondering if there's a way to set a user's password through the API? I can't find an API call to do it, and the passwords are encrypted when stored in t_secusers.
Cheers,
/Uffe
Stefan Bolleininger
Re: Set user password?
« Reply #1 on: October 17, 2011, 11:57:16 pm »
You can set the password through the normal EA-Security
Click "Project->Security->Manage Users", selct the user  and use the "Change Password"
Of course you need the security priviledges to do this.
« Reply #2 on: October 18, 2011, 01:24:27 am »
Why would you set the password via API? What's your use case?
Uffe
« Reply #3 on: October 18, 2011, 02:06:09 am »
I have a large number of users to be imported, and need to set a default password so users can log in after the (DBMS) repository has been transferred to an .EAP.
Or do users get assigned a default password I am unaware of? I haven't tested this in 9.0, but if I remember correctly, you have to set a password explicitly if you want to be able to log into the project after you've taken an .EAP off-line (no AD connection).
« Reply #4 on: October 18, 2011, 04:52:21 am »
Hmm. I haven't even found a way to create a user via the API. However, you can set the password to null (or blank) in t_secuser. In that case the user can log on with no password. Which is kind of the same as having a default password.
Maybe you can try setting a password and use the crypt value for someone else and see whether the logon works.
« Reply #5 on: October 18, 2011, 06:23:58 pm »
In fact I can confirm that it works.
Two users with the same password have the same hash in the t_secuser.Password table.
So and update/insert statement passed on to Repository.Execute() should do the trick.
