Author Topic: Adding existing toolbox pages to extended diagram  (Read 7139 times)
WarrenKenyon
« on: August 26, 2017, 07:33:07 am »
I am creating a simple MDG to do some requirements modeling.  I wanted to extend "Requirement" to create a stereotype unique to our current problem, specifically to add a set of tagged values.  I really just want to add my new requirement type to the existing "Requirements" toolbox and diagram type. I believe that is not really possible, so I went ahead and created a tool box and diagram type for my MDG.  That all works fine.  But, I really want the "Extended Requirements", "Requirements Relationships" and "Patterns" pages you get when you create a UML::Requirements diagram.
Is there any way to simply add those pages to my new diagram type/toolbox?  The Extended Requirements page contains a bunch of stereotyped Requirements, but they are not "UML::xxx". I have not been successful in creating a toolboxpage in my profile that adds those Built-in Types, because they are not Built-in Types.  I believe they are part of "Core Extensions" but I don't know how to address that MDG in my profile (since it is internal and not an XML file)
WarrenKenyon
Re: Adding existing toolbox pages to extended diagram
« Reply #1 on: August 26, 2017, 09:45:29 am »
I did extend UML::Feature. What I want is the rest of the requirements tools available in the same tool box.
WarrenKenyon
« Reply #2 on: August 29, 2017, 06:56:03 am »
You can type in the meta types manually if they are not present.
Except I cannot, because the other requirements types seem to be extensions themselves, and are not UML::xxxx.  I know how to add UML default meta types to a tool box.  These seem to be in another namespace that is known only internally.
« Reply #3 on: August 29, 2017, 08:55:18 am »
EAREQ::FunctionalRequirement(UML::Requirement)
The rest follow the same pattern. If you get stuck, create one in an empty model and then look in t_xref for a definition like this
@STEREO;Name=FunctionalRequirement;FQName=EAREQ::FunctionalRequirement;@ENDSTEREO;
« Last Edit: August 29, 2017, 09:45:54 am by KP »
WarrenKenyon
« Reply #4 on: August 29, 2017, 09:49:41 am »
Thank you.  A real answer from someone who seems to have actually read the question.
