Author Topic: Adding a set of attributes to a large number of elements  (Read 7290 times)
Bulent
« on: September 06, 2017, 12:52:36 am »
Is there a quick way of adding the same set of attributes to a large number of elements?
Re: Adding a set of attributes to a large number of elements
« Reply #1 on: September 06, 2017, 05:47:37 am »
No. EA still is not OO in many respects. The only way is to write a script (which is fairly easy).
« Reply #2 on: September 06, 2017, 10:39:22 am »
You can drag a set of attributes from the browser of one element to another element on a diagram (thereby adding a copy to the destination).  However, if you have VERY many that's still tedious.
Guillaume
    • www.umlchannel.com
« Reply #3 on: September 06, 2017, 06:18:59 pm »
Here is a suggested script to create the same attributes on the classes within the selected package. It can be improved to loop through the subpackages, only update classes with a given criteria such as a tagged value, etc.
option explicit
!INC Local Scripts.EAConstants-VBScript
' Script Name: Populate attributes (package script)
' Author: Guillaume[at]umlchannel.com
' Purpose: Create the same set of attributes on each class within the selected package
' Date: 6/09/2017
sub OnProjectBrowserScript()
' Get the type of element selected in the Project Browser
dim treeSelectedType
treeSelectedType = Repository.GetTreeSelectedItemType()
select case treeSelectedType'
case otPackage
dim thePackage as EA.Package
set thePackage = Repository.GetTreeSelectedObject()
dim allObjects as EA.Collection
dim currentElement
set allObjects = thePackage.Elements
dim i
for i = 0 to allObjects.Count - 1
set currentElement = allObjects.GetAt( i )
if currentElement.Type = "Class" then
addAttribute currentElement, "attr1"
addAttribute currentElement, "attr2"
addAttribute currentElement, "attr3"
end if
next
case else
' Error message
Session.Prompt "This script does not support items of this type.", promptOK
end select
end sub
sub addAttribute(ClassToProcess, attributeName)
dim attributes as EA.Collection
set attributes = ClassToProcess.Attributes
dim newAttribute as EA.Attribute
set newAttribute = attributes.AddNew( attributeName, "" )
newAttribute.Update()
attributes.Refresh()
end sub
Hope it helps.
Guillaume
