Author Topic: Webpage Wireframe - Table Control - ReOrder Columns?  (Read 5295 times)
wmather
« on: September 15, 2017, 12:31:08 pm »
Is there an easy way to sort the columns of the table without having to destroy columns to put things in the order you require for your technical specifications?
I tried to edit the memo note XML directly, but that did not work.
Any help would be appreciated as surely I am not the only one to have this requirement?
VKN
Re: Webpage Wireframe - Table Control - ReOrder Columns?
« Reply #1 on: September 15, 2017, 02:49:23 pm »
As of current version of EA there is no way to re-order the columns.
You can rename the column names by right clicking on it, if that helps.
