Author Topic: Use Cases structured scenarios and parameters  (Read 4183 times)
dambsst_gmail
    • dcgblimited
« on: September 17, 2017, 10:18:17 pm »
Does anyone know how to add more than 1 parameter using the "Uses" column of the structured scenarios?
It works great to generate the activity diagrams with action pin or activity parameters, but it seems not possible to add more than 1 parameter.
By example, if in the "Uses" column I write "MCU, Firmware" the generated parameter will be "MCU, Firmware".... I have tried many separators but none are working it copies directly what is written in this column.
Also it would be great if it can synchronize the parameters directly from the "invoked" use case....
