Author Topic: Relating features to requirements  (Read 22313 times)
Glassboy
« on: September 18, 2017, 02:44:19 pm »
I've been reading the help and looking at the example models but there doesn't seem to be an example that shows the relationships generally used to join a feature to a requirement.  (Not to mention issues and risks).
http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/model_domains/feature.html
What's the optimal?  And does it work well with the relationship matrix?
Re: Relating features to requirements
« Reply #1 on: September 18, 2017, 06:27:35 pm »
I usually use <<trace>> relations from features to requirements. Though I have not used it with the RM there should not be any issue (but that could be <<trace>>d in another dimension).
Helmut Ortmann
« Reply #2 on: October 06, 2017, 07:22:04 pm »
from my experience traceability and relationship-matrix works well. You may use the <<trace>> stereotype as qwerty mentioned. But any other or self-defined stereotype works as well.
With EA you can link almost everything together. The only limits are your imagination.
If you work a lot or with a team in this area it would be a good idea to standardize your method and use a MDG to support your types (stereotypes and tagged values) like features or so. You have to define the stereotypes as meta-types to use them in a Relationship Matrix.
There are two other features worth looking after:
- Charts (for metrics, versatile)
- ModelViews to visualize as free definable table (arbitrary complex, also for metrics)
Best regards,
Helmut
Glassboy
« Reply #3 on: October 09, 2017, 07:17:52 am »
Well obviously but I've been watching the toolbox grow on the requirements diagram and it looks there is a "method to the madness" that isn't being reflected in the help pages or in the sample models.  There was always a chance someone here had more of a clue than I do.
