Author Topic: Help page Guidebooks currently contains no books  (Read 10848 times)
PeterHeintz
Best regards,
Peter Heintz
Sunshine
  • Its the results that count
Re: Help page Guidebooks currently contains no books
« Reply #1 on: September 19, 2017, 06:53:19 am »
Happy to help
« Reply #2 on: September 19, 2017, 07:24:12 am »
I guess not. It's more like a hint to Sparx: Hey, your page is incomplete.
RoyC
  • Read The Help!
« Reply #3 on: September 19, 2017, 10:12:34 am »
Not sure where the problem lies. I have clicked the link you attached, and there is a short intro paragraph and a Topics button. Clicked on the button, a short menu of options. Selected an option, clicked on the Topics button, and a huge list of guides displays for that subject area.  Can you do that?
Or you can use the PDF versions of the same documents, which Sunshine linked to.
Best Regards, Roy
« Reply #4 on: September 19, 2017, 11:36:41 am »
It should be clearer that you need to press the topics button.
I would venture to say that most people do NOT use the "[<Prev]" or "[Next>]" buttons to navigate the Help system, so "[Topics>]" on its own is unfamiliar.
It DOES look like an incomplete page if you're used to "point and click" on links.
RoyC
  • Read The Help!
« Reply #5 on: September 19, 2017, 02:35:10 pm »
Hey Glassboy, can you nitpick again and tell Paolo that you don't press a screen button, you click on it?
I will forward your point to the decision-makers.
Best Regards, Roy
« Reply #6 on: September 19, 2017, 04:44:47 pm »
It was a Surface Pro and I pressed it.  :P
(and what's more, it worked!)
PeterHeintz
« Reply #7 on: September 19, 2017, 09:26:48 pm »
Ok, I opened this issue because when I was on page http://sparxsystems.com/resources/user-guides/index.html#guidebooks
I expected to see what is on page:
Now I realized that link 1 is just a html representation of link 2 with an UI I personally was not able to use.
Best regards,
Peter Heintz
RoyC
  • Read The Help!
« Reply #8 on: September 21, 2017, 11:48:30 am »
Those two links look identical to me. Could you, Peter, clarify what your problem was? What UI could you not use?
To respond to Paolo's earlier point, the web interface people are now investigating how to make the Topics button more self-explanatory. It isn't as simple as it might seem, because the header line has to be able to massage itself to fit into an iPhone display as well. No promises.
Best Regards, Roy
« Reply #9 on: September 21, 2017, 12:09:02 pm »
To respond to Paolo's earlier point, the web interface people are now investigating how to make the Topics button more self-explanatory. It isn't as simple as it might seem because the header line has to be able to massage itself to fit into an iPhone display as well. No promises.
A simple additional text at the bottom of the page:
"To see further topics, use the [Topics>] button to navigate further."
would suffice!  8)
Gosh, that could be the tooltip on the [Topics>] button,   ;)
RoyC
  • Read The Help!
« Reply #10 on: September 21, 2017, 01:32:24 pm »
YesyesyesyesyesNooooo.
Most topics are longer than a display screen, so if someone doesn't want to read the topic but move to another, they won't see the message at the bottom of the topic. They might not even read the text even if the topic is short enough to display on one screen.  You have to label the Topics button as the thing to click on to see more topics. Calling it 'Topics' is not enough for some people.
Best Regards, Roy
« Reply #11 on: September 21, 2017, 02:27:34 pm »
Maybe try calling them what they are...  Subtopics.
Verily thou sayest that the topic is what one seeth on the screen, therefore the others be below this one, and be thus subtopics.
PS: I May have been called "Pope Paul" at various times, but I'm not "The Vicar"!  ;)
« Last Edit: September 22, 2017, 09:42:34 am by Paolo F Cantoni »
Glassboy
« Reply #12 on: September 22, 2017, 08:25:31 am »
Well the lenovo stinkpad I'm currently using allows me to press a screen button, so I don't think I'm the person for this job.
Also I've been trying to learn more about the BA stuff in EA recently and I've been in some of those sections of the help site and the navigation is a little bit confusing.
