Author Topic: Client and Repository versions compatibility question  (Read 4612 times)
jankari
« on: September 19, 2017, 09:49:09 pm »
The question is regarding a setup where EA uses a database repository.
Can an EA 12 version client use a database with EA 13 schema version?
Also, can an EA 13 client use a database with EA 12 schema?
Thank you in advance for your time and input.
Re: Client and Repository versions compatibility question
« Reply #1 on: September 19, 2017, 09:58:47 pm »
Yes. There's absolutely no problem to mix V12 and V13 clients. The database is very stable and changes, if ever, are more marginal.
jankari
« Reply #2 on: September 19, 2017, 10:03:26 pm »
Thank you for such a quick response, querty. Appreciate your sharing your insight.
