Author Topic: Model Search : Metatype/Class return is “Pot Luck”  (Read 3653 times)
« on: September 20, 2017, 04:47:59 pm »
We have an extensive set of metatypes and the Model Search will use the metatype as a synonym for the type field.  The problem is that the rendering appears to be "potluck".  For the same search with the same result set (in terms of objects returned - in this case, ALL of the same metatype), a varying number of the entries will have the type set to the metatype and others to the base class.  Run the same search again, a bit later and a different subset of the same result set will have the metatype and the rest the base class.
Anyone else seeing this?
