Author Topic: Model Search: How to inhibit null <Search Term>  (Read 4397 times)
« on: September 20, 2017, 04:55:08 pm »
Is there any way through the normal Model Search mechanism to stop the user running the search with a null <Search Term>?
A user accidentally did that and the search returned a result set and it took us a while to figure out why.  Because the result set with the <Search Term> and without the <Search Term> were the same it looked like a bug, but it's not (just a coincidence).  However, the lack of the <Search Term> might not be noticed.  This particular search NEEDS a <Search Term>.  How can we make sure the user provides one?
TIA,
Re: Model Search: How to inhibit null <Search Term>
« Reply #1 on: September 20, 2017, 05:40:48 pm »
If you are using an SQL search you can make sure that there is no result when the user doesn't fill in the search term.
Otherwise I don't think there is much you can do.
« Reply #2 on: September 20, 2017, 06:08:57 pm »
Thanks, Geert,
That's what I thought.  I'll await any reply from the Sparxians.
