Author Topic: Glossary: mismatch of multi-word term over line breaks  (Read 6244 times)
Uffe
« on: September 27, 2017, 07:23:29 pm »
Hi all,
It seems the glossary term highlighting feature doesn't work correctly for multi-word terms over line breaks.
If there are two multi-word glossary terms where one is a prefix of the other (as in "Some property" and "Some property type"), and you use the longer one in a notes field somewhere, if a line break should appear between "property" and "type", EA will highlight only "Some property" on the first line and pop up its meaning. If you resize the window to fit the whole phrase on one line, it instead highlights "Some property type" and pops up that meaning.
This is the case in 11.1, but that's so old now I don't want to report bugs on it. Can someone check this in the current version?
Cheers,
/Uffe
Re: Glossary: mismatch of multi-word term over line breaks
« Reply #1 on: September 27, 2017, 07:56:37 pm »
Yip, still a problem in 13.5.1351
Uffe
« Reply #2 on: September 27, 2017, 08:17:54 pm »
OK, thanks. Reported.
/U
« Reply #3 on: September 28, 2017, 09:33:11 am »
/U
+1 x 10
