Author Topic: Shape script on profile  (Read 6857 times)
Modesto Vega
« on: September 28, 2017, 09:19:41 pm »
I have created a profile with a number of extensions to base classes. I have attached the shape script below to one of the stereotypes extending the base class. The script draws the right geometry but the connectors look odd. There are 2 problems:
1) one end of the connector, the bottom end, is a few pixels inside the rectangle
2) if I change the stereotype of an element in the diagram to the stereotype with the same scripts, a significant amount of white space appears between the bottom of the shape and the end of the connectors
Have I missed anything? (Sparx EA version is 13.0.1310 Build 1310).
shape main{
rectangle(0,0,100,100);
addSubshape("stereotypecompartment", 100, 20);
addSubshape("namecompartment", 100, 20);
shape stereotypecompartment
h_align = "right";
editablefield = "stereotype";
rectangle(60,0,100,60);
println("#stereotype#");
shape namecompartment
h_align = "center";
editablefield = "name";
println("#name#");
Re: Shape script on profile
« Reply #1 on: September 28, 2017, 09:34:16 pm »
I could not reproduce either of the effects you see.
Modesto Vega
« Reply #2 on: September 28, 2017, 10:33:45 pm »
Which version of EA are you running?
« Reply #3 on: September 28, 2017, 10:45:41 pm »
I tried with 1351.
Modesto Vega
« Reply #4 on: September 28, 2017, 10:48:25 pm »
I tried with 1351.
Thanks, I will check if an upgrade fixes the problem.
Modesto Vega
« Reply #5 on: September 28, 2017, 11:42:45 pm »
Interesting this appears to fix the problem without upgrading - same idea different coding.
Just 3 additional questions:
1) is there anyway I can make the fonts of "stereotypecompartment" and "namecompartment" different and independent/
2) can I set the fill color of "stereotypecompartment" to mid-gray?
3) how I increase the line width of the enclosing rectangle?
shape main{
addSubshape("stereotypecompartment", 50, 50);
addSubshape("namecompartment", 100, 100);
h_align = "left";
v_align = "top";
rectangle(0,0,80,50);
h_align = "center";
printwrapped("#name#");
Uffe
« Reply #6 on: September 28, 2017, 11:50:25 pm »
There's not a lot you can do with fonts in shape scripts. You can set the colour, but not the size or typeface.
For the others, take a look at SetFillColor() and SetPenWidth().
/Uffe
