Author Topic: Requirements Tagged Values and Sysml Parametrics  (Read 3712 times)
qaus
« on: October 25, 2011, 06:35:18 pm »
I am new user of Enterprise Architect and need urgent help.
I want to use Enterprise Architect for requirement management and want to see the impact of changing requirements on the other system parameters.
I just want to create an application where there are no. of requirements (each requirement has some parameters and their specified values i.e. tagged values).There is sysml parametric diagram designed for some inputs and outputs.Can I take the values from tags of Requirements and use them as Inputs to the simulation.Is it possible in Enterprise Architect?
Or
Please Help me I have one more idea to do this i.e. Software Development through Enterprise Architect because my system just need mathematical values as output.Can I develop a software in Enterprise Architect where there are no. of classes and each class can preform some mathematical calculations and passes these results to other classes.How can write mathematical equations in the code generated by EA and How to debug,Run and Test that code but still I need to pick tagged values from requirements as input for testing?
Urgent replies and Detailed guidance is highly required.I have referred user guide,documentation and help provided at sparxsystems.
Re: Requirements Tagged Values and Sysml Parametri
« Reply #1 on: October 25, 2011, 11:18:44 pm »
Definitely possible, but you're going to do a bit more effort from you side I guess to get some answers here.
This forum works best if you have a specific problem that you need an answer for like: "How do I read the value from a requirements tagged value" or something like that.
« Reply #2 on: October 26, 2011, 06:30:29 am »
What Geert means: you need to dig into automation. You will (AFAIK) not be able to do that out-of-the-box with the SysML MDG.
