Author Topic: Filtering Matrices  (Read 8347 times)
Modesto Vega
Filtering Matrices
« on: September 29, 2017, 11:20:04 pm »
Matrices can be filtered by (element) Type -  e.g., Actor, Class, Component and so on - but is there a way to also filter the contents of a matrix by stereotype. To give some context to the question, the stereotypes I have in mind are extensions of the base classes using a UML profile.
In a nutshell we are ending up with matrices with too much superfluous data, if we could filter by stereotype they will just have the relevant data.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: Filtering Matrices
« Reply #1 on: September 29, 2017, 11:50:27 pm »
Note the source of the row or columns of the matrix could be a selected package or a search. If you select a search, you can specify the search filter using the parameters you want, as the stereotype and any other.
« Reply #2 on: October 02, 2017, 10:55:06 am »
That's the route we've taken.
We've found we use a lot of TVs to enable us to control which items appear on which matrix.
Modesto Vega
« Reply #3 on: October 03, 2017, 02:12:26 am »
Thanks Arquesoft and Paolo. Will give a try.
Paolo - what do you mean with TVs.
« Reply #4 on: October 03, 2017, 10:48:51 am »
[SNIP]
TV => Tagged Values
