Author Topic: Specifying ActivityParameter direction in profile  (Read 7788 times)
Uffe
« on: October 02, 2017, 11:25:49 pm »
I'll tell you what I want, what I really really want:
I want the different directions of ActivityParameters (in, out, inout, return) to be displayed differently in diagrams.
I can create stereotypes with shape scripts which set different colours -- but how do I specify that when using my «outpar» ActivityParameter stereotype toolbox item, an 'out' ActivityParameter should be created as opposed to an 'in' one which is the default?
I realize that this is slightly incorrect use of stereotypes. But there's no way to check for the element's 'direction' in a shape script -- it doesn't have its own property for retrieval, and it's not a tagged value.
Cheers,
/Uffe
Re: Specifying ActivityParameter direction in profile
« Reply #1 on: October 03, 2017, 08:23:34 am »
This works...
shape main
if(hasproperty("direction","in"))
setfillcolor(255,0,255);
drawnativeshape();
« Reply #2 on: October 03, 2017, 08:32:27 am »
In your profile, give your "ActivityParameter" metaclass element an attribute named "direction" with initial value "out". This appears to work, but it's possible it only works for properties named "direction".
« Last Edit: October 03, 2017, 08:34:02 am by KP »
Uffe
« Reply #3 on: October 03, 2017, 08:04:11 pm »
This works...
[snip]
Ah! So it's not that the property isn't available for retrieval, it's just that it isn't documented.
OK. But now that you showed me how to get the shape script to work I can make a single stereotype «actpar» rather than four different ones, which is better because it means a modeller can't set the direction to conflict with the stereotype.
Cheers, KP!
/Uffe
« Reply #4 on: October 03, 2017, 08:51:26 pm »
I think I have seen it one in a shape script (from which MDG was that?). Maybe a grep for "hasproperty" through Geert's lib could give some additional enlightenment.
P.S. Here's the result of such a grep. First is the first hasproperty paramenter and the second are the 2nd parameters used
BPMNexpanded   1
BPMNmarker   1
classifier
diagram.mdgtype   BPMN2.0::Conversation
diagram.mdgtype   SOMF_dg::SOMFDesign
direction   bi-directional
direction   destination -> source
direction   source -> destination
direction   Unspecified
incomingedge   bottom
incomingedge   right
incomingedge   top
iscomposite   true
IsDrawCompositeLinkIcon   false
parentEdge   Bottom
parentEdge   Left
parentEdge   Right
parentEdge   Top
Partition   Horizontal
partition   vertical
rectanglenotation   0
rotationdirection   down
rotationdirection   left
rotationdirection   right
rotationdirection   up
ShowComposedDiagram   false
ShowComposedDiagram   true
Source.Metatype   Decision
stereotypehidden   true
type   association
type   class
type   Package
P.P.S. The help only comes up with that: http://sparxsystems.com/enterprise_architect_user_guide/12.1/building_models/query_methods.html which is more than nothing, but leaves a lot room for guessing. I'll have to update my ShapeScript book with a bit background.
« Last Edit: October 03, 2017, 10:09:55 pm by qwerty »
