Author Topic: Add-in Usage with Citrix  (Read 6733 times)
kjourdan
« on: October 06, 2017, 11:33:06 am »
Is there a way to use locally developed add-ins with EA accessed via Citrix?  The Citrix server host many different databases for different products / projects so the add-in should only be accessible to myself and others that are working on the same project.  When I access the models through the thick client, my add-in is available but the performance is slow because of the location of the database.  Accessing through Citrix, I have good performance but my add-in not available.
VKN
Re: Add-in Usage with Citrix
« Reply #1 on: October 06, 2017, 02:01:03 pm »
Sparx doesn't support Citrix.
Even if you get around one problem, you may face another.
« Reply #2 on: October 07, 2017, 11:35:24 pm »
EA works with Citrix, and you can get add-ins to work on Citrix as well, but not without a struggle.
I'm not sure why, but when installing something on a Citrix environment the registry keys seem to be forgotten by the system.
Last time I had to get the Citrix guy to set all registry settings in the login script.
Glassboy
« Reply #3 on: October 09, 2017, 07:22:28 am »
Because being virtual desktops a lot more clean up is done when a user logs off.  So if something isn't exactly where it should be it won't be there next time a user logs on.  Windows has a feature called Group Policy Preferences which came in with Windows Server 2008 which is better for fixing these things than log on scripts.
