Author Topic: Diagram script: selected element feature  (Read 6748 times)
Uffe
« on: October 06, 2017, 06:27:38 pm »
Hey guys,
Is there a way to retrieve the currently selected element feature (I mainly need attributes and operations) in a diagram?
The information is there, because you can right-click an operation and find it in the project browser -- but is it available in the API? All I can get out of the Diagram class is the selected connector and elements.
It's no, right? The answer is no?
/Uffe
Helmut Ortmann
Re: Diagram script: selected element feature
« Reply #1 on: October 06, 2017, 07:26:50 pm »
Hi Uffe,
you can access the selected attribute, operation by script. The snippet in C#. You have to translate it into your Scripting Language. The API ist the same:
ObjectType objectType = _model.Repository.GetContextItemType();
int id;
switch (objectType) {
  case ObjectType.otAttribute:
  id = ((EA.Attribute)_model.Repository.GetContextObject()).AttributeID;
Best regards,
Helmut
Uffe
« Reply #2 on: October 06, 2017, 10:22:34 pm »
Heeeey,
Yes! That works! :)
Now unfortunately, if you select an attribute or operation in a diagram and right-click it, there's no Script sub-menu.
But you can select the feature first, then move the cursor to some other part of the element and right-click, and the script will pick up the selection. So that's close enough.
Thanks!
/Uffe
