Author Topic: Not working properly on Surface Pro  (Read 5825 times)
lambsland
« on: October 08, 2017, 07:23:46 am »
I have EA 13.5 on a Surface Pro and Asus Laptop.  The Apply / Release Lock does not appear on both the context menu and from the Design panel works fine.  It works fine on the laptop.  Has anyone come across this issue
Re: Not working properly on Surface Pro
« Reply #1 on: October 08, 2017, 07:29:59 am »
Are you using the same EA user? Have you turned on security?
lambsland
« Reply #2 on: October 08, 2017, 11:19:40 am »
Yes and yes
« Reply #3 on: October 08, 2017, 06:26:15 pm »
So there's the issue. Either use the user with the right privileges or enable the Surface user for using Lock Elements.
« Reply #4 on: October 09, 2017, 08:58:24 am »
If the item doesn't appear in the menus at all, look at the Menu Set
