Author Topic: EA clear the file. Now 's empty 0Ko  (Read 29280 times)
Bebert
« on: October 09, 2017, 11:29:24 pm »
My main file is 0 ko size. EA can't open anymore. Obviously it 's empty.
I don't understand why EA clears my file. How it's possible.
I use EA13.5
BR
Re: EA clear the file. Now 's empty 0Ko
« Reply #1 on: October 10, 2017, 12:00:09 am »
I've never seen or heard anything like that, so it seems unlikely to me that EA is the culprit.
But with a case like this I would contact Sparx support. Maybe they can shed some light on this.
I don't think however they can magically bring back your model, so I hope you still have a backup.
Bebert
« Reply #2 on: October 10, 2017, 01:36:36 am »
The other problem : our backup logs see only modification on the ldb file no on the eap. that's mean I don't have recent back up. the last one is on july. Why in july I don't know.
« Reply #3 on: October 10, 2017, 02:21:04 am »
You only recognize that your backups did not work when you need them.
Bebert
« Reply #4 on: October 10, 2017, 02:40:18 am »
Not really, the behavior of the  .eap is odd.
I thought It was the backup but it works fine with all the files .ldp included.
I could provide the backup log to the EA team.
PeterHeintz
« Reply #5 on: October 10, 2017, 03:52:49 am »
eap files in fact are MS Access mdb files.
So, more or less what .doc is/was for Word.
So if you have lost this file you have lost your model.
The .ldb is a MS Access temporary file that exist if a mdb/eap is open only. For you as a user it is more or less useless. To see what .ldb is intended for, see here:
https://support.microsoft.com/en-us/help/966848/what-is-an-ldb-file
If your eap has size 0, nothing but a backup could help you.
I personally have never seen such a problem and I would assume it has something to do with your environment rather than with MS Access or EA on top of it.
Best regards,
Peter Heintz
« Reply #6 on: October 10, 2017, 08:29:00 am »
You can contact Sparx per mail, but a 0k EAP simply means you got nothing. EAP == MDB (or whatever that suffix was for Mickeysoft Access). What Peter said...
VKN
« Reply #7 on: October 12, 2017, 02:14:50 pm »
EA doesn't empty your file by itself.
Looks like your model has been moved/deleted and a new model is created through the Windows folder (New | Enterprise Architect Model) which currently creates an .eap with a size of 0 (Sparx is aware of this).
Check the Date created flag.
« Reply #8 on: October 13, 2017, 01:00:42 pm »
To clarify VKN's response.
We currently know of only one scenario that can cause a 0 byte eap file. That is, the Windows Shell 'New' command creates an empty file without asking Enterprise Architect to fill it.
Unfortunately, by definition, the presence of a 0 byte file delivers no information about why it is 0 bytes. If you describe your processes that may suggest additional possibilities for the cause.
Glassboy
« Reply #9 on: October 13, 2017, 01:21:30 pm »
That's not true, it tells you it's not an event that creates the database schema.  The file also has all the normal file system meta-data attached to it which tells you who and when it was created.
So as you have indicated the how, the OP just has to look at the meta-data to find out the who and then when.  Once they know the who they can ask them why.
That's quite a long way forward in clearing up the mystery.
(argumentum ad ignorantiam)
« Reply #10 on: October 13, 2017, 05:34:57 pm »
[SNIP]
And it's Friday the 13th!
« Reply #11 on: October 13, 2017, 08:29:24 pm »
Not being picky but just ignorant: where does Windoze store the creator in file attributes? I can only see Size, Created/Modified/Accessed and R/W.
Glassboy
« Reply #12 on: October 16, 2017, 07:58:46 am »
My crystal ball doesn't tell me what version of Windows you're using or which of the approximately 5 local file systems it supports.  Or if you're looking at a network drive how good the underlying implementation of CIFS is :-)
But in general some metadata will be in the Master File Table (MFT), some will be in meta-files and some in Alternate Data Streams (forks).
What you see depends on the exact file system, and Windows, OSX, and *NIX all implement the same concepts in different ways.
« Reply #13 on: October 16, 2017, 04:28:35 pm »
Me still thinking that NTFS is Mickeysoft's ultima ratio.
sargasso
« Reply #14 on: October 16, 2017, 07:23:16 pm »
(This is probably a furphy, but anyway.)
I recall that about a million years ago there used to be a problem with the Jet engine when the MDB file was stored on a network drive. I did a bit of a search through the forum but cannot find anything apropos. All I really can remember is that one symptom was "suddenly" empty mdb files.  It was not an EA problem, as I said it was something about the Jet engine.
Anyway I would presume that by now that issue would have been resolved, so this is probably a furphy.
b
