Author Topic: Shape script: action pin parameter type  (Read 8440 times)
Uffe
« on: October 11, 2017, 02:07:00 am »
Hi all,
In a shape script, and without resorting to an Add-In, is it possible to retrieve the parameter type for an action pin?
The problem is that the action pin is an instance type, and its classifier is the corresponding activity parameter -- not the type (classifier) of that activity parameter. And there's no classifier.classifier.type property to be retrieved.
/Uffe
Uffe
Re: Shape script: action pin parameter type
« Reply #1 on: November 08, 2017, 01:21:45 am »
Hi Uffe,
The type you're after is the pin's property type. You can retrieve its classifier, if it has one, using the undocumented property propertytype.type.
/Uffe
« Reply #2 on: November 08, 2017, 02:53:46 am »
Hi Uffe,
/Uffe
auch Uffe, when you start talking to yourself that's the beginning of the end :o
« Reply #3 on: November 08, 2017, 03:04:00 am »
No, no. They are actually two persons. Dr. Uffe and Mr. Hyde.
« Reply #4 on: November 08, 2017, 12:38:34 pm »
I've suspected that for a while!  ;D
Besides, so long as you get the right answers, talking to yourself is fine...
RoyC
  • Read The Help!
« Reply #5 on: November 08, 2017, 03:44:48 pm »
That's an interesting side-effect of the clone element functionality... in Uffe's case we will call it a feature. In the interests of it not becoming a bug, I won't follow Uffe's procedure!
Best Regards, Roy
