Author Topic: Setting defaults for Attribute Visibility  (Read 4370 times)
eric.meredith
« on: October 12, 2017, 02:30:50 am »
I am finding myself right-clicking on each and every server node and manually setting the visible attributes to a specific one (IP Address) clikcing on "Custom" checkbox, then "Custom" button, and then deselecting the ones I don't want. After that I click the checkbox to display Notes.
Is there a way to make these choices the default? Or is there a way to do this en masse?
Eric
Re: Setting defaults for Attribute Visibility
« Reply #1 on: October 12, 2017, 05:41:50 am »
You could try with a template diagram, though I don't think the custom setting is supported. Just try it out. Else you can write a little script that will do that for you.
« Reply #2 on: October 12, 2017, 02:34:29 pm »
Also try the template package.
I think that will allow you to set the default for "show notes".
