Author Topic: Urgent! Repository.GetConnectorByID fails!  (Read 3730 times)
« on: October 12, 2017, 04:39:44 pm »
I'm using a VBA library I've used for nearly a decade to process repositories (both EAP and SQL Server) with Excel.  Today for the first time in a while I tried to use Repository.GetConnectorByID().  It failed to return the requested Connector!  The connector exists and is confirmed by the fact that Repository.GetConnectorByGuid() with the correct GUID will return the connector with the correct ID!
Can anyone reproduce?  This is on an Access 2000 repository - because I'm off-line and can't access the corporate SQL Server repository.
Integrity Checker says there are NO problems.
Help!
Reported,
