Author Topic: UseCase is not legal for Actor --> UseCase  (Read 6075 times)
BruceTOGAF2
« on: October 24, 2017, 06:09:41 pm »
Even though I can build this connector manually, why is my Jscript being prevented from building a "UseCase" connector between an Actor client and a UseCase?
My Jscript function connectSupplierClient() has 3 input parameters
•   mySupplier
•   myClient
•   connectorType
function connectSupplierClient() works well for a range of elements types and connector types, but refuses to work with
•   an Actor element
•   a UseCase element
•   connector type "UseCase"
I have tried passing the
•   Actor element as mySupplier
•   UseCase element as myClient
•   UseCase element as mySupplier
•   Actor element as myClient
In both cases, I get runtime error message "UseCase is not legal for Actor --> UseCase"
There is nothing to stop me building the above model using the toolbox, but I cannot build the above model with Jscript. Any idea why?
Re: UseCase is not legal for Actor --> UseCase
« Reply #1 on: October 24, 2017, 06:18:41 pm »
I guess it must be a bug.
Turning off the strict connector syntax settings will probably allow you to do this anyway.
« Reply #2 on: October 24, 2017, 06:47:06 pm »
I had no problem creating a connector this way. Hmmm. Any strange add-ins running?
BruceTOGAF2
« Reply #3 on: October 24, 2017, 11:27:12 pm »
According to 'Manage Add-Ins', I only have 2 Available Add-Ins. They are enabled and set to Load on Startup:
Visual Studio
Eclipse
How do I turn off this restriction?
Do I use 'EA_OnPreNewConnector()' at the top of my Jscripts?
What is the syntax?
« Reply #4 on: October 25, 2017, 12:04:21 am »
Tools/Options/Link (bottom left check box).
I have this option set and it does NOT croak. So I'd suggest you try with the add-ins turned off temporarily.
BruceTOGAF2
« Reply #5 on: October 25, 2017, 12:33:21 am »
Problem solved!!!
Tools/Options/Links
I unchecked the checkbox 'strict connector syntax'
My Jscript function connectSupplierClient() now works well when building a "UseCase" connector between an Actor and a UseCase
Thank you Geert and qwerty.
« Reply #6 on: October 25, 2017, 01:36:00 am »
Still makes me wonder why on my side this does not make a difference. But I won't dig into that mud ;-)
