Author Topic: Schema composer, specify association to sub-class of an association end  (Read 5114 times)
joep
I am trying to create a message schema using schema composer. I would like make use of an inherrited association:
I have a root element called PSREvent which has an association to a class called PowerSystemResource. In my schema specification I would like to have an association between PSREvent and ACLineSegment, which is a specialization of PowerSystemResource.
How can I do this?
Re: Schema composer, specify association to sub-class of an association end
« Reply #1 on: October 24, 2017, 08:11:18 pm »
Joep,
First drag the subclass into the left pane with the classes.
Then choose redefine on your association and select "as choice of" and check your subclass.
joep
« Reply #2 on: October 24, 2017, 09:03:23 pm »
Hi Geert,
I think i'm getting somewhere :)
I only see the option `restrict this property' when I right click on my association. This does have the option `as choice of'. Is that the one you mean?
I seem to only be able to point to direct child classes of PowerSystemResource, not to child classes of its child classes. How can I descent more than one inheritance level?
Joep
« Reply #3 on: October 24, 2017, 09:30:40 pm »
Yes
You can't. Please send in a bug report. We've already done so, but the more bug reports they get, the sooner it will get fixed.
