Author Topic: Drag & Drop diagram as hyperlink – Run auto layout is “sticky” and can’t be chan  (Read 5058 times)
When you Drag & Drop a Diagram from the browser onto another diagram (as a Hyperlink), the "[ ] Run auto layout" is sticky and on my machine is set to true and disabled - so I can't change it!
VERY inconvenient!
Reported,
Glassboy
I feel like this happens somewhere else too.  Can't quite remember where.
Apparently, I wasn't the first to report it.
There is a workaround:
Currently the "Run Auto Layout" option will only be active if you have the "Navigation Cell" option selected, however, the auto layout still applied when using other options (such as dropping a hyperlink). To avoid the auto layout, select "Navigation Cell", then untick "Run Auto Layout", then select the option to drop the hyperlink.
