Author Topic: Script driven Fragment with new lines  (Read 4180 times)
philchudley
« on: November 10, 2017, 01:18:46 am »
Hi All
I am developing a script for a documentation template fragment.
Part of this involves processing a list of GUIDS from a refGUIDList tagged value, getting each GUID is easy, but as part of the XML returned which contains several custom fields, I wish to return a CustomField called, say ELELIST which is a newline delimited string of element names
Does anyone know how to achieve this?
I have tried using \n as the delimiter as well as
 all are simply ignored during documentation generation and all element names appear on a single line of text.
Phil
Models are great!
philchudley
Re: Script driven Fragment with new lines
« Reply #1 on: November 10, 2017, 01:44:18 am »
Hi All
I have solved the problem
The delimiter to be used is <p> (HTML Paragraph)
The string representing the custom field is added to the XML with a formatted attribute with a value of 1
Cheers
Phil
Models are great!
