Author Topic: MDG Custom Diagram - does not set diagram type or diagram stereotype?  (Read 11746 times)
Svend Erik Nygaard
  • Business Information Architect
I created a custom diagram type in an MDG.
When I use the MDG, I can select my custom diagram type when I create a new diagram
BUT:
  • The new diagram does not get a customized type - it is still just "Component"
  • The new diagram does not get a customized stereotype - it is still blank in the stereoype
  • If I try to change the stereotype in the properties field, my new stereotype does not show up
  • The new diagram does not get a customized stereotype (in diagram peoperties window) - it is still blank in the stereoype
If I go to Design/Diagram/Manage/Change type... - then I can actually choose my new diagram type, but I still don't see any change in the diagram's type og stereotype.
The diagram pane's title bar does show the new customized stereotype though (<Steretype> diagram: <name>
EA also presents the associated toolboxes correctly
Does EA not set diagram type and stereotype in the usual fields (Diagram_Type and Stereotype) for a customized diagram?
I can see that it does include the name of my customized stereotype (CityMap) in the field StyleEx:
"MDGDgm=CPH_MetaModel::CityMap;HideQuals=0;HideConnStereotype=0;"
Re: MDG Custom Diagram - does not set diagram type or diagram stereotype?
« Reply #1 on: November 10, 2017, 04:27:06 am »
I'm pretty sure what you saw is normal behavior for EA.
« Reply #2 on: November 10, 2017, 08:09:05 am »
If you create any diagram from BPMN you see that they are Analysis diagrams and don't have a stereotype. It's only that EA knows the meta-type and associates a toolbox with the diagram.
« Reply #3 on: November 10, 2017, 11:00:19 am »
Because Diagrams are 2nd (or lower) class citizens of the sparxian ecosystem, a diagram metatype is NOT a combination of Type and Stereotype, but just an entry in StylEx (as noted by the OP).
Getting Diagram stereotypes to appear in the dropdown has been problematic for us.  IIRC we found we had to place them in the General stereotypes list with a base class of Diagram to get them to show up.
Svend Erik Nygaard
« Reply #4 on: November 10, 2017, 10:55:33 pm »
But that will not associate the MDG's diagram type with the general stereotype - correct?
Is there any way to add a stereotype (possibly as a default value) from within the MDG, to elements created from the MDG's diagram type?
« Reply #5 on: November 10, 2017, 11:19:15 pm »
I'm sorry I don't understand what you mean with "elements created from the MDG's diagram type"
Svend Erik Nygaard
« Reply #6 on: November 11, 2017, 12:51:45 am »
Yeah, that was a bit of fast typing, sorry.
I mean:
I create a customized diagram type "CityMap" in my MDG.
Then, when the user creates a new CityMap diagram, I want EA to set the diagram's stereotype to "CityMap"
Is there any way, I can specify in my MDG, that the diagram should automatically be given the stereotype "CityMap" - for instance, can I, in my MDG, specify a default value for the Stereotype property?
« Reply #7 on: November 11, 2017, 06:49:14 pm »
Ah, thanks that makes more sense.
No I don't think you can, but diagram stereotypes aren't really valid UML constructs you know.
Why is it so important that you have a stereotype on your diagrams? I've done a number of MDG with diagram types, and I never really felt the need for stereotypes.
What would be nice is if we could specify our own icon for a diagram. That would visually set them apart from the other diagrams.
« Reply #8 on: November 11, 2017, 10:56:28 pm »
+1
« Reply #9 on: November 13, 2017, 12:06:43 pm »
+1
+1
Svend Erik Nygaard
« Reply #10 on: November 15, 2017, 05:06:28 am »
  • Searching
  • Reporting
  • Applying logic/rules/quality checks
« Reply #11 on: November 15, 2017, 03:47:58 pm »
Can't you do all of that without the stereotype as well?
« Reply #12 on: November 15, 2017, 08:12:11 pm »
Yes, but it's inconvenient (due to inconsistency). You need to look after the "stereotype" of a diagram in StyleEx in the MDGDgm tag.
« Reply #13 on: November 15, 2017, 10:38:38 pm »
No argue with that.
