Author Topic: Can you restrict the return result to just the <Search Term>  (Read 6310 times)
« on: November 15, 2017, 12:44:12 pm »
If I search for the search term "Party"; in our repository, I get 66 results only 6 of which are for the exact term "Party".  The search is a contains search, so the effective search term is "*Party*".  Is there any mechanism short of adding a new exact match search that allows me to change the contains to an equals search?
Re: Can you restrict the return result to just the <Search Term>
« Reply #1 on: November 15, 2017, 02:44:54 pm »
You mean set the condition to 'Equal To' instead of 'Contains'?
Or do you mean that you want whole word only?
« Reply #2 on: November 15, 2017, 05:50:53 pm »
The latter, which effectively changes the condition from contains to equals.
« Reply #3 on: November 15, 2017, 08:16:22 pm »
Sort of the flag type "Match whole word" in addition to the search field, I guess. This is being found in many search machines, but would be the base for a new feature request here (I guess again).
« Reply #4 on: November 16, 2017, 08:21:29 am »
Equals is a completely ineffective as a description for the behavior you are after.
Regardless, what you are after doesn't exist.
RoyC
  • Read The Help!
« Reply #5 on: November 16, 2017, 09:41:39 am »
You could try changing the search term to " Party " (put a space before and after the word). Or search just with a space before, then search just with a space after.
Best Regards, Roy
« Reply #6 on: November 16, 2017, 10:30:50 am »
(my emphasis)  YMMVWFM  It is EXACTLY a description for what I'm after.  If I change the contains to equals and enter the term: Party  I get exactly the 6 I'm after.
However, as you say, the mechanism doesn't exist and so I have to create new searches.
@Roy, neither of your suggestions work.  They DO restrict the result set, but not in the way I'm after.
RoyC
  • Read The Help!
« Reply #7 on: November 16, 2017, 11:15:05 am »
I have thought about permutations of the word 'Party' and Neil has made a few observations too; basically, I agree with Simon.  Your search would have to be set up like a spell checker to encompass all the conventions you might use in assigning element names (are you searching for just element names?) with capitalization, punctuation, non-alphabetic characters, use of phrases or single words etc.
« Last Edit: November 16, 2017, 02:31:51 pm by RoyC »
Best Regards, Roy
