Author Topic: Can you use multiple values in <Search Term>  (Read 8190 times)
« on: November 16, 2017, 03:28:09 pm »
We have a Project Search that uses the IN operator:
TaggedValue.Value IN ('<Search Term>')
If a single value is supplied, it works fine.  Is there any way to get multiple values in?
I even tried "tricking" the query by making <Search Term>= value1', 'value2
hoping the resulting '<Search Term>' phrase would look like:
'value1', 'value2'
which works; if I hardcode it.  But to no avail!
Is there any way to achieve the multiple values?  Is it actually the expression of a defect?
TIA,
Helmut Ortmann
Re: Can you use multiple values in <Search Term>
« Reply #1 on: November 16, 2017, 10:39:08 pm »
Hi Paolo,
try:
select * from t_object where name in (<Search Term>)
with Search Term:
"rte","bsw"
Kind regards,
Helmut
« Reply #2 on: November 16, 2017, 10:58:03 pm »
with Search Term:
"rte","bsw"
Should be 'rte','bsw' with single quotes instead of double quotes to be correct SQL syntax.
Some databases don't care, but others will.
« Reply #3 on: November 17, 2017, 10:47:55 am »
Hi Paolo,
try:
with Search Term:
"rte","bsw"
Kind regards,
Helmut
Hi Helmut,
I'm on the bus so not conncted to our corporate repository, but I found that
didn't even compile.  I didn't even get as far as entering the term to test it.
However, it won't work anyway.  Did you get it to work?  Seems to be a problem with quote bracketing.
« Reply #4 on: November 17, 2017, 08:01:31 pm »
I got it to work on an EAP repo. You need to supply the search term with double quotes.
Helmut Ortmann
« Reply #5 on: November 17, 2017, 10:55:35 pm »
I only tested it with *.eap files. That's one of the issues with SQL.
What I see is:
- Make an Add-In Search
- Make a Script
Kind regards,
Helmut
« Reply #6 on: November 20, 2017, 10:36:52 am »
Yes, it's database-dependent. I couldn't get it to work with a Firebird repository, doesn't like the double quotes.
« Reply #7 on: November 20, 2017, 10:49:21 am »
Which version of EAP?  A97 or A2000?  Also, are you using ANSI-92 Searching?  We do for compatibility with our SQL Server DBs.
« Reply #8 on: November 20, 2017, 05:04:40 pm »
Uhm. I don't have any Mickeysoft product on this virtual machine - it's mainly EA. It's running on a XP (yes, still). So it's basically that what Sparx delivers.
« Reply #9 on: November 20, 2017, 05:48:17 pm »
In that case it will be A97 which we can't (and don't want to) use.    :(  I'm pretty certain that the double quotes will work only with A97.
Is that the same with you Helmut?
Helmut Ortmann
« Reply #10 on: November 20, 2017, 09:19:09 pm »
Hi Paolo,
I've only tested it with *.eap files created by EA. I think this is A97.
Helmut
