Author Topic: Notes linked to element note feature do not display text after source import  (Read 4443 times)
heba
Hi all,
I have some diagrams with notes linked to elements (classes) and their content linked to the element feature "Element note".
The class was created using reverse engineering from source.
After running reverse engineering again the class gets updated. Its element note remains as it is but text from the note disappears. :(
I can "repair" this by opening the dialog "Link this Note to an element feature..." and just pressing OK. So the text is not lost and there must be something wrong with the link.
Did anyone else run into this issue or has some more information?
Thanks in advance!
Heiko
You should probably report that as bug (use link below on this page in the Support section).
