Author Topic: Document generation failed for glossary  (Read 7619 times)
fausto bertoli
« on: November 22, 2017, 01:37:41 am »
We have created a very simple document template element using the standard glossary template just to print it inside a word document.
EA respose with a dialog saying: document generation failed.
The same message raise also even if we print only that document template alone.
Any suggestions?
rRgards.
Fausto
Re: Document generation failed for glossary
« Reply #1 on: November 22, 2017, 05:51:10 am »
What do you mean by "Document template element"?
fausto bertoli
« Reply #2 on: November 22, 2017, 08:11:22 am »
I mean the doc template to be used to generate a document referring packages from several models
fausto bertoli
« Reply #3 on: November 22, 2017, 09:10:40 am »
I have solved the problem.
i created a model document referring the glossary document template,  but this model document do not refer any paragraph. If i insert at least one paragraph , doesn't matter which, the proble disappear.
thansk.
Fausto
