Author Topic: Adjusting Heading Depth when using Virtual Documents  (Read 4383 times)
Screwtape
« on: November 23, 2017, 11:07:23 pm »
Hi!
I'm generating a virtual document using a script with all the necessary sections etc. instead of using a script to generate the whole document.
However, there is one feature when using the script process that I can't find in the virtual document system - that is adjusting heading depth - as was done using the nDepth parameter of say, the DocumentElement method.
When I want to document nested elements etc., it appears that I have to create separate templates if I want to have different heading levels, which is a bit frustrating, as I would need to change the levels of all the subheadings.
(I don't document the nested elements using >>ChildElement entries because that documents all of them using the same template which defeats the point of the virtual document).
Have I missed something, or do I need to create a feature request?
Thanks!
Screwtape
Screwtape
Re: Adjusting Heading Depth when using Virtual Documents
« Reply #1 on: November 24, 2017, 12:04:28 am »
I think you should indeed send in a feature request.
