Author Topic: DiagramLink question  (Read 4368 times)
SMaric
« on: November 14, 2011, 09:43:33 pm »
Can someone please explain the usage of
ConnectorID - The ID of the associated connector.
and
InstanceID - The connector identifier for the current model.
I am finding that these values are identical for some connectors and not for other connectors
Re: DiagramLink question
« Reply #1 on: November 15, 2011, 12:47:18 am »
The ConnectorID is a unique ID for all connectors in the repository. I have no idea what the InstanceID is. Maybe it is used with association classes?
« Reply #2 on: November 15, 2011, 08:56:28 am »
A connector may appear on more than one diagram. So in the diagram links table (t_diagramlinks), the connector ID won't be unique; the instance ID will be.
SMaric
« Reply #3 on: November 15, 2011, 07:37:06 pm »
That makes some sort of sense --
So if the connector is ONLY used on a single diagram
Then connector ID == instance ID
?? Correct ??
« Reply #4 on: November 16, 2011, 09:07:48 am »
?? Correct ??
No, they're completely different numbers (although if you average one diagram per connector for the life of a model - which is not unreasonable - the numbers will be very close).
