Author Topic: Changing tag grouping does not work. Work around => SPARX HANGING/CRASHING  (Read 14102 times)
adepreter
When a tag grouping is changed in an MDG the Synchronized Stereotype function does not update the grouping on existing elements.
(almost a) work around: Move existing elements to a diagram.
However when there are hundreds of elements than Sparx freezes when dragging the elements on the diagram. Equivalent to Sparx CRASHING.
This bug makes Sparx EA look like a toy. Users are very disappointed.
This is our third request since 2016 for a descent work around (program, script.. whatever).
Re: Changing tag grouping does not work. Work around => SPARX HANGING/CRASHING
« Reply #1 on: December 19, 2017, 11:32:59 pm »
Alain,
If you figure out what EA is changing when putting an element on a diagram, then you can do the same in a script for all of them.
You might want to use something like SQL server profiler to get a grip on what EA is exactly changing.
adepreter
« Reply #2 on: December 21, 2017, 02:09:26 am »
Great idea!
Thank you Geert.
adepreter
Though I think Sparx really needs fix this problem anyway.
In that case you should send a bug report.
