Author Topic: Disable "Show Namespace" by default/for all diagrams  (Read 6746 times)
Macki
« on: December 21, 2017, 10:51:54 pm »
is it possible to globally disable the "Show Namespace" option for all existing diagrams, which is available on the property page of a diagram? I only found the option "Disable fully scoped object names" in the global Diagram options/preferences, but that doesn't hide the package name below the component. Or is it at least possible to change the default behavior for new diagrams, so that this option is disabled by default for new diagrams?
Thanks and regards
Markus
Re: Disable "Show Namespace" by default/for all diagrams
« Reply #1 on: December 21, 2017, 11:14:49 pm »
Markus,
Have you tried this using the template package?
You would have to set that up for each type of diagram individually.
Macki
« Reply #2 on: December 22, 2017, 03:05:35 am »
Hi Geert,
thanks for the hint, it works perfectly fine with new diagrams! I guess changing all existing diagrams is not possible?
Markus
« Reply #3 on: December 22, 2017, 03:27:16 am »
Hi Geert,
Markus
It is, but then you would have to write a script or something.
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #4 on: December 25, 2017, 01:16:50 am »
You might have to use SQL to update, T_DIAGRAM.SHOWFOREIGN (TRUE / FALSE)
