Author Topic: Enterprise Architect - User Tips  (Read 21686 times)
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« on: December 29, 2017, 01:52:46 pm »
EA has never failed to surprise me with hidden gems every now and then. I've also been asked repeatedly to share EA tips and tricks to make things easier.
We've started a post in LinkedIn (EAUG) (https://www.linkedin.com/groups/1356/1356-6349523866678816768)  to share these tips. Starting this thread to share these tips here too, as suggested by fellow users.
Nizam
  • Prolab Moderator
Re: Enterprise Architect - User Tips
« Reply #1 on: December 29, 2017, 01:58:08 pm »
Sharing the tips shared thus far (Thanks to Phil Chudley, Daniel Bjarsch for the contribution). Request fellow EA Users in this forum to please contribute too. TIA
  • Use 'Ctrl + Click' to quickly create elements. Create one element (say Class) using toolox and then use 'ctrl+click' to repeat the same item
  • Use F3 to repeat the last connector. Add a new connector from toolbox or quicklinker, and then use F3 to repeat the last connector.
  • Uncheck 'Edit Object on New' in Preferences -> Object Tab to disable properties dialog. This will let you create elements quickly using above techniques.
  • use shift +right click to get the toolboz anywhere in the diagram.
  • Draw elements without toolbar by simply using 'ctrl +shift +arrow keys
  • Ctrl + w to add a new view or package to a currently selected model root view or package
  • Autosize (Alt + z) resizes objects to best fit. This can be quite handy when you enable / disable Element's Features (Feature Visibility)
  • Pin your favorite toolboxes using 'More Tools -> Set Toolbox Visibility'. This enables the desired toolbox in all diagrams
  • Space bar in an open diagram opens Toolbox context menu
  • Change line styles for multiple connectors at a time using 'Relationships Window'. Select a few objects in the diagram, see all its connectors in the relationship window -> Right click -> Line Style -> Choose desired line style
Nizam
  • Prolab Moderator
« Reply #2 on: December 30, 2017, 03:31:45 am »
You can select an item in a diagram,  then use 'ctrl +shift + arrow keys' to create an item without using a mouse.
Nizam
  • Prolab Moderator
« Reply #3 on: December 30, 2017, 05:31:12 pm »
Use 'alt+g' to find a selected element in Project Browser
Nizam
  • Prolab Moderator
« Reply #4 on: December 31, 2017, 04:59:17 pm »
use 'ctrl + U' to find an element usage across other diagrams
Nizam
  • Prolab Moderator
« Reply #5 on: January 01, 2018, 07:47:48 pm »
use 'ctrl + Tab' to switch between diagrams. one of the less known, highly useful feature to flip between item diagrams.
Nizam
  • Prolab Moderator
« Reply #6 on: January 02, 2018, 12:21:23 pm »
select an object in diagram, hold ctrl and drag to a new position to create object as new ( copy)
Sunshine
  • Its the results that count
« Reply #7 on: January 03, 2018, 08:29:02 am »
Whilst I admire your enthusiasm I think there are two problems with your approach.
« Last Edit: January 03, 2018, 08:37:26 am by Sunshine »
Happy to help
Nizam
  • Prolab Moderator
« Reply #8 on: January 03, 2018, 03:37:28 pm »
Thanks for the note, i wasn't intending only shortcuts, but selective usage tips. This is something I get asked in every training, to have a place where people can share their tips. i was hoping  EA users here would contribute as they find something interesting. Will do for a  sometime, and if  it is not seen highly relevant in the forum, will leave it there.
Nizam
  • Prolab Moderator
« Reply #9 on: January 03, 2018, 03:37:59 pm »
Use Traceability window to quickly drag and drop a related item into the diagram. Simple Drag and drop (Classes, Components, etc) or Right click and 'Place element in Diagram' (Activity, events, etc)
Nizam
  • Prolab Moderator
« Reply #10 on: January 04, 2018, 02:05:27 pm »
Copy attributes or operations  from one class to another by just dragging and dropping from Element Browser (Select source class, choose the intended attribute and drop it on the target class)
Graham_Moir
« Reply #11 on: January 09, 2018, 10:21:00 pm »
While I understand what Sunshine is saying, I actually find this quite useful.
Nabil
    • View My LinkedIn Profile Here
« Reply #12 on: January 10, 2018, 12:56:00 am »
Posting a tip from my old community article (unpublished now because of broken links)
Differentiate incoming & outgoing connectors of an element. Select an element in a diagram (workspace) and press "L" (keyboard) to highlight. Incoming flows will be highlighted in Red and Outgoing in Green.
Cheers
Nabil
« Last Edit: January 10, 2018, 04:54:33 pm by Nabil »
Nabil
Nizam
  • Prolab Moderator
« Reply #13 on: January 10, 2018, 02:50:51 am »
Use the 'Create multiple Elements' utility (diagram toolbox by pressing space or ctrl right click in a diagram) to quickly create multiple elements at a time.
Nizam
  • Prolab Moderator
« Reply #14 on: January 10, 2018, 03:01:18 am »
Thanks.  Just thought this could be one thread which we all could share our little tricks that makes a modelers life more interesting.
