Author Topic: Orphaned EA.exe process - Interop.EA.dll [Solved]  (Read 6277 times)
wmather
« on: January 04, 2018, 12:11:26 am »
I am trying to automate the generation of my own documents by using a hybrid repository to walk all the required tables and assemble the required records.
This all works well, but as soon as I use EA.Repository() to save images, after my application finished, I have rouge EA.exe processes still running.
Is there something I am doing wrong so that the COM API closes the EA instance it has opened?
This is my code. Normally I let GC run in it's own time, but just forcing in-case it was the GC holding some COM lock. Please note this is EA 13.5.1352 Professional Edition
        private void ExportDiagrams()
            var eaRepos = new EA.Repository
                SuppressEADialogs = true,
                SuppressSecurityDialog = true
            eaRepos.OpenFile(options.EAPFile);
            foreach (var d in Diagrams)
                d.SaveImage(options.WorkingDir, eaRepos);
            eaRepos.CloseFile();
            eaRepos = null;
            GC.Collect();
        // inside my Diagram class...
        public void SaveImage(string dirName, EA.Repository repository)
            var pi = repository.GetProjectInterface();
            repository.OpenDiagram(Diagram_ID);
            pi.SaveDiagramImageToFile($@"{dirName}\\{Diagram_ID}.jpg");
            pi = null;
            repository.CloseDiagram(Diagram_ID);
« Last Edit: January 04, 2018, 12:59:37 am by wmather »
Re: Orphaned EA.exe process - Interop.EA.dll
« Reply #1 on: January 04, 2018, 12:47:30 am »
I think you need to call Repository.Exit()
wmather
Re: Orphaned EA.exe process - Interop.EA.dll [Solved]
« Reply #2 on: January 04, 2018, 12:58:33 am »
damn! did not see that function even though it was in my face  :P
And yes, that does solve the problem as well
