Author Topic: HTML Publish automation and the need to be logged in  (Read 9593 times)
Eamonn John Casey
« on: January 05, 2018, 07:40:15 pm »
I have made a utility to run the HTML Publish automatically on a Schedule but the user needs to be logged into the machine for it to work. Does anyone know of a workaround to make this work? I read about a Windows Service wrapper but that only seems to wrap my utility and not the Enterprise Architect instance.
What I really want is to be able to Reference models from Confluence where we do documentation.
Will WebEA/Pro Cloud help here?
Thanksin advance,
Eamonn J.
Re: HTML Publish automation and the need to be logged in
« Reply #1 on: January 05, 2018, 08:47:35 pm »
Has been mention many times before: you need a logged on user to operate EA. Use a workstation and a post-it "Do NOT log off".
« Reply #2 on: January 08, 2018, 08:45:21 am »
Absolutely.
Pro Cloud provides a HTML view into your model, there's no reason to run a HTML report at all.
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #3 on: January 08, 2018, 06:09:19 pm »
Thanksin advance,
Eamonn J.
You can run your application in Session 0, your application will then execute EA in Session 0 too .  This runs the application at an elevated privilege and without any active user session.
Refer
https://blogs.technet.microsoft.com/askperf/2007/04/27/application-compatibility-session-0-isolation/
https://msdn.microsoft.com/en-us/library/ms682429.aspx
(PS - Windows Server 2016 does not support Interactive Services)
Glassboy
« Reply #4 on: January 09, 2018, 08:54:37 am »
Session 0 is unlikely to be a context that will authenticate against a database in a situation where you are using integrated security.
Nizam
  • Prolab Moderator
« Reply #5 on: January 09, 2018, 02:43:58 pm »
For automated publishing we could have an admin user / dedicated user to open  the repository. We've done automated HTML, DocX and XML publishing engines for a few of our clients who use EA Security as well
Uffe
« Reply #6 on: January 11, 2018, 09:47:56 pm »
There is something called Scheduled Tasks in the cloud server. This appears to be exactly what's needed: a way to do EA things in a server context.
However, this is "currently" limited to updating a time series chart and has been since it was first introduced, so it's demo-level functionality. Maybe if enough users push for it, this could be extended to run an HTML report and other useful things (see more suggestions here).
Unfortunately, I think it's unlikely we'll see any movement on this. The scheduled tasks functionality seems destined to remain a (nother) demo hack that no one uses, and Sparx likely see this problem as a way to push users onto the $3000-$8000 per year cloud server. And that can't do server-side automation either -- it only gives you an HTML view, which is not the same as a generated HTML report.
/Uffe
