Author Topic: MDG - Calculating a tagged value from other tags - simple example for beginners  (Read 4805 times)
kpietrusewicz
Hello Friends,
I am using Enterprise Architect 12.1 Ultimate Edition.
I started my journey with creation of own meta-models with the use of MDG technology.
I am the beginner and would like to ask You for help with the topic as follows:
1. 'stereotype_1' with tagged values: Integer1, Integer2
2. 'stereotype_2' with tagged value: Integer3, Integer4, Integer5
Within the model I will have plenty of 'stereotype_1' elements, while only couple of 'stereotype_2' for summary of information from 'stereotype_1' elements.
It will be like:
1. Integer3 = sum of all Integer1 values from the same diagram
2. Integer4 = percentage of Integer2 values from the same diagram, with some given Integer5 max value
My question is how to update tagged values from 'stereotype_2' based on the values from tagged values of 'stereotype_1'.
Thank You for Your kind support!
There's noting out of the box for that. But there are two alternatives. First you can run a simple (!) script that does the calculation and updates everything according to your rules. That should be doable in a day (or even less). The second is more comfortable but also more labor for the programmer. An add-in can check for tag updates and do the calculation on the fly. It's not that difficult and could be implemented as a second step.
Nabil
    • View My LinkedIn Profile Here
Hello Friend,
Run a script which does this tag calculations and update it. (This you have to run every time manually)
 or
As you have mentioned based on elements on diagram. I assume elements are already created based on diagram change you need to perform this operation.
you can try EA_OnPostNewDiagramObject & EA_OnPostCloseDiagram events put your logic in this will do the things on fly you can combine your MDG with Addin as well.
Best Regards
Nabil
Nabil
kpietrusewicz
Thanks for Your kind response :-)
Yes, it took one working day.
Script is not perfect, but solves my problem.
Best regards,
Krzysztof
